Game Changer and Exhaust
Old May 4, 2015 | 08:58 AM
PwhirL's Avatar
Default Game Changer and Exhaust
2014 JKU, just ordered Metalcloak Game Changer 6 Pak edition. I need a "relocated exhaust" what is recommended? I like deep throaty sounding stuff, like Borlas on a Cobra for example. Thanks.
Old May 4, 2015 | 09:26 AM
Invest2m4's Avatar
You don't really need to relocate. I ran the same lift last year. All I did was get a 1310 driveshaft. At full droop it would contact the exhaust, but you would rarely if ever droop both wheels together.
However, the solution to that would be to have a shop weld in two exhaust spacers. The logic here is that it is a proper fix and also the spacers can be welded on a flat section of pipe so that it doesn't push the crossover down, just back. Save yourself the money.
If you are set on an exhaust, Dynomax seems logical since you get 90 days to try it. Can't really go wrong there.
Old May 4, 2015 | 09:27 AM
Dynomax's Avatar
Sponsoring Manufacturer
We offer a couple options for the 2014 JKU.
Both are around 5-6 out of 10 on sound.
P/N 39522 is our pre axle dump and relocates the muffler under the driver seat.
Single - 2.5" Cat-Back System - Ultra Flo? Polished Muffler - P/N: 39522 - DynoMax® Performance Exhaust
P/N 39523 relocates the muffler and exits all the way out back.
Single - 2.5" Cat-Back System - Ultra Flo? Polished Muffler - P/N: 39523 - DynoMax® Performance Exhaust
Rebate too:
DynoMax® Performance Exhaust Promotions
Good luck on your choice.
Old May 4, 2015 | 10:20 AM
mattgt5's Avatar
I went with the dynomax axle back system and it cleared the rear away bar once it was relocated. My stock muffler was too big and made contact.
sent from my work leash
