Want to replace 14mm bolts in control arms w/9/16"; Will swap affect alignment?
I just got my JKU aligned today, and it's still got a little bit of a wobble around 45 mph. I'm not sure if maybe it's because the tires are worn a little bit due to previous misalignment or something else. Caster came in at 3.4/3.7.
Got all new Front & Rear Synergy Trackbars; Drag link (Drag link flip kit); Frame side trackbar bracket; Teraflex ball joints.
I'm thinking of swapping out the bolts in my factory control arms with the 9/16 bolt kit to see if that will affect anything. Does anyone know if I swap out the bolts one at a time, will affect the alignment? I don't wanna spend anymore $$ at the alignment shop.
It shouldn't affect it enough for it to matter either way. If you have adjustable control arms, get a angle finder. Check the angle before and after the bolts are installed. Then, adjust accordingly. You may want to try out 4-5 degrees, or anywhere in between. I would assume you'd have some driveline vibrations at that low of castor. Could be wrong though.
Assuming that the trackbar bracket holes are not severely wallowed out, and the bolts are torqued down tight, swapping the bolts will have no effect on the caster. 'If' the holes are way wallowed out and the bolt is loose, and you replace the bolt and crank it down - maybe? A tiny bit? Not likely, but...
I replaced the bolts on the trackbars.
To answer the question, about the low caster, I have adjustable uppers, but the alignment shop was trying to optimally dial it in to 3.5. I'm thinking of taking it back And telling them to adjust it out to 4.
However also a little side note, my camber was off on my passenger side by 2.4 degs about 2 months ago, so I had to put in a 2 deg offset balljoint to get it back into spec. I'm wondering if moving the caster forward yesterday was pushing the camber back out.
Sorry for the sloppy reply. Am on my phone at Harbor Freight.
