Rancho RS9000XL shocks, Settings
Old May 8, 2015 | 02:45 AM
sullivan9162's Avatar
Default Rancho RS9000XL shocks, Settings
Have just received my new RS 9000 rancho shocks, not sure of which #'s to use on adjustable settings....do most of you using these, just use one setting for all around use or change the settings for hwy to offroad use??? what are preferable #'s for hwy??? for offroad (moderate trails in Ouray and Moab) ???thanks....2010 JKU, RK 2.5 Max Travel lift, 5.13's, 33' AT tires, stock front and rear bumpers.
Old May 8, 2015 | 03:46 AM
bevan7170's Avatar
Clear coat them several times before installing. Only had mine a year and the are rusted and rotting already.
Old May 8, 2015 | 05:37 AM
karmynsbeep's Avatar
Former Member
I've not had rust issues but I keep a coat of wax on my frame and as far as settings I run the lowest setting front and back the ride is unbelievable! I'm running synergy springs and rock crawler lowers
www.overlandoff-road.com
Old May 8, 2015 | 07:48 AM
Unlimited_X's Avatar
3 in front, 4 or 5 in the back it can get a little woggly back there so some control is needed.
Old May 8, 2015 | 05:53 PM
jeepmojo's Avatar
Default mine are covered in surface rust too :(
One winter , mine are rusting grrrr I love the ride of these shocks but not the rust factor ! They surely could give them better protection at the factory i feel , the clear coat is just not good enough for a NewEngland winter with road salt but they do make my jeep ride 100% better . Setting i found i like is 4 in rears and 2 up front
Old May 8, 2015 | 08:53 PM
kjeeper10's Avatar
Vet Army
Try Fluid Film .. Works wonders on everything.
