JK Differential Rebuild
Hi All, I have just recently purchased Yukon 4.56 gears and ARB Lockers for my 2012 JK Sport. I am looking for recommendations or advice on Master Rebuild Kits for the Dana 30 front and Dana 44 rear that includes all the shims and good bearings without breaking the bank on the Yukon rebuild kits.
Thanks!
Thanks!
Thanks!
Thanks!
Nitro Gear Change Package Kits - 1 Part number Front & Rear Gears, Install Kits - New Products - Nitro Gear & Axle
I used Motive master install kits. I only paid 100 bucks each for the kits, that's with Timken bearings. I got them here: https://www.knowwhere2jeep.com/
Make sure what size ring gear bolts you need for each set up. I also have Yukon gears F/R and went with F/R truetracs. The stock rear ring gear bolt is 1/2", which would have required me to drill out the carrier. Luckily the Yukon rear ring gear was duel drilled. If I remember correctly, the front IS NOT. Just double check and make sure you have what you need.
