ESP issue is getting old!
Old May 16, 2015 | 05:16 PM
3Fletch's Avatar
Default ESP issue is getting old!
I have read the posts about disabling with the steering wheel shuffle, switch, fuse etc. I recently took my 2007 down to have the update flash to allow full disable... No dice! I have tried the sequence about 10 times and it will not work! I am contemplating the switch but I cannot stand lights on the dash. I have had it aligned, re calibrated for tire size, steering wheel centered etc. and it still acts up on most turns. Please tell me there is a solution!
2007 Wrangler Jk 2 door sport... 3-1/2" lift running 35" Swampers.
Old May 16, 2015 | 05:30 PM
Jeek.OlllllllO's Avatar
Originally Posted by 3Fletch
I have read the posts about disabling with the steering wheel shuffle, switch, fuse etc. I recently took my 2007 down to have the update flash to allow full disable... No dice! I have tried the sequence about 10 times and it will not work! I am contemplating the switch but I cannot stand lights on the dash. I have had it aligned, re calibrated for tire size, steering wheel centered etc. and it still acts up on most turns. Please tell me there is a solution! 2007 Wrangler Jk 2 door sport... 3-1/2" lift running 35" Swampers.
yeah same here, couldn't get mine to work so I just deal with the three lights on my dash
Old May 16, 2015 | 05:34 PM
DunnyBunny's Avatar
JK-Forum Ambassador
What is the steering wheel shuffle etc?
Old May 16, 2015 | 05:42 PM
AR JK RUBI's Avatar
http://www.fourwheeler.com/how-to/el...ontrol-system/
Old May 16, 2015 | 05:50 PM
nthinuf's Avatar
I like how that article calls it the hokey pokey, and says it may take four/five/six attempts to get it right. You would think that they could have come up with a better solution. But I guess for liability, people are extremely unlikely to do this by accident...
I could never get mine to shut off completely either, but maybe it's time to give it another shot.
Old May 16, 2015 | 10:16 PM
holmes4x4's Avatar
did you check all your joints ball joints etc?? and is it saying its only an issue on one side ??
Old May 17, 2015 | 05:28 AM
3Fletch's Avatar
Yes all ball joints, tie rod ends etc. are in great shape. Not sure what you mean by the last sentence? It acts up on right hand and left hand turns.
Old May 17, 2015 | 05:42 AM
Invest2m4's Avatar
Could it just be a bad wheel speed sensor? Those don't last forever. I had a lot of issues last year and turned out to be mud on a rear tone ring.
Old May 17, 2015 | 05:49 AM
14Sport's Avatar
...or possibly a worn unit bearing.
Old May 17, 2015 | 08:24 AM
txjeeplover's Avatar
As others have pointed out, it could be a bad steering or suspension component, wheel sensor, or even an issue with the clockspring about to go. The disabling process is intentionally cumbersome and awkward, but it does work. I'll note that I learned the hard way that after doing the dance, it sometimes require driving the Jeep a short distance and turning for the desired result to take effect.
