Rear bumper hitting quarter panel??
When I go off roading, the rear bumper looks like it hits the quarter panel if hit it going down and stuff. I did hit the bumper going down a hill but not too bad like I have seen before. Is this normally an issue I have to worry about? Isn't this something that the bumper is supposed to protect?? Its a smittybilt XRC atlas bumper. I love the bumper but it has chipped a tiny piece of paint off already on my new -14 jeep :[ and its right down to bare metal. I have it covered with a piece of tape until I can get a hold of my touch up paint. The bumper is torqued to spec so I don't know what I should do. Will smittybilt do anything about the bumper or my panels? Am I being a total NEWB about this? lol
I have the same experience with the Genright aluminum bumper but it never messed up my paint until I got a small pebble in that seem. Mostly it was the black paint in the aluminum that chipped off right there. A little touch up paint worked for me. Mine is an 09 I wheel a lot so it's not as shiny as a 14.
The rubber bushings flex on the JK allowing the body to tilt a little bit when you flex the suspension. Bumpers that hug the quarter panels close might touch, so the only thing I can think of is to take the bumper off and trim that 1/4 piece that is close to allow more room. I was going to do this to mine but never worried because it was the bumper paint that was suffering.
Yeah I have my bumper covered with a piece of tape for now until I can get a hold of some cover up. That might be a good idea to just cut the bumper down though! The bumper does have some flex for instance when I jump on it
so I can probably figure that it is way worse when it hits on the trail. Ugh...well time for a new cut off wheel/grinder :P lol
Sounds like you need to adjust the bumper a little lower. The bumper is mounted to the frame and the body sits on flexible mounts on the frame, so as the body flexes, it can contact a bumper if there is not enough clearance. That said, most bumpers have plenty of clearance. I'd make whatever tweaks are needed. There is another thread around where someone had the same issue and eventually it caused the entire body panel weld seam to crack where the corner meets the side. That is a mess.
Ah yeah see there is no way this bumper can be dropped down like that. It too attaches to the hitch as well and whatnot. Wait so if its the body that is flexing, which I do understand. It might save me the hassle of grinding and adjusting the bumper if I just do a body lift correct? Its fairly cheap and I can do about an inch no problem
Haha! oh of course. well too bad for me I just picked up a set of 35s like two days ago lol anyways that is seeming like it might be the only option though. Ill see if smittybilt says anything about it, if not I think thats what I will end up doing though. Too bad its all 1 inch kits, I was looking for something just enough to clear it but oh well.
