35s and 3.21
Old Jun 4, 2015 | 04:47 PM
2doorjkinblack's Avatar
Default 35s and 3.21
What's up I have a 13 jk auto running 35s and 3.21 , I did the procal tuner to account for the tires but I am thinking of regearing what geat should I go too? It's my daily and I plan to go to 37s when I need new rubber
Old Jun 4, 2015 | 05:07 PM
Ozzie's Avatar
Umm I would say atleast 4.56 - 4.88 gears. I have 4.10 and I am running 35s and no problems. Just a suggestion
Old Jun 4, 2015 | 05:18 PM
Beemerman's Avatar
I would do 488 if you gonna do 37s. I have 35s and run 456.
Sent from my iPad using JK-Forum
Old Jun 4, 2015 | 05:50 PM
ade's Avatar
ade
4.56 with the 3.6 is good and will keep the revs down at highway speeds. If you do a lot of crawling 4.88 would help.
Old Jun 5, 2015 | 05:38 PM
Would 5.13 be too much?
Old Jun 5, 2015 | 06:47 PM
twofourflinching's Avatar
4.88 would be sweet spot with 37s
Old Jun 6, 2015 | 05:10 AM
12JKjeep's Avatar
no need for 5:13 on a 2012 or newer jk unless your going up larger then 37's. I run 4:88 with 37's and it's great off-road. Rpm's are a little high on the highway but not to bad.
Old Jun 6, 2015 | 03:39 PM
Ok cool thank you what's the logic behind it though 4.88 5.13 5.38 , 35 37 40 what would be the difference or the benefits of the ratios?
Old Jun 6, 2015 | 05:09 PM
kmrtnsn's Avatar
Daily driver and 37"s? I hope you planning on upgrading to Dana 60s front and rear with the regear.
Old Jun 7, 2015 | 08:01 AM
Mike H.'s Avatar
I don't know how people can recommend a gear ratio without knowing if you wheel, what terrain you wheel, how you wheel, which t-case you have, what daily driver means to you or what the speed limits are in your area?
