Rock Krawer lift users tired of tying up your sway bar fix!!
Hey guys, I finally had enough of zip tying up my sway bar, every time I wanted to put it in the rocks. I knew there had to be a better way!! I found a swaybar bracket from Teraflex for $38 that would almost be perfect. The only downside, was that the RK swaybar links, were too small to fit the peg offered with the Teraflex kit: https://www.amazon.com/gp/mobile/dp/...tag=your_order
After those came in, we contacted RK and ordered the correct bolts to fit their links. You don't need everything on the list that I'm including...I had lost some of the nylon washers. The jam nuts also aren't required, as the bolts already come with them. All that is left when you get everything is to drill out the bracket to the size of the bolt. Hope this helps someone else!!
