Tired of the annoying flap flap flap seat belt over 35 mph? No more!!!
Old Jun 7, 2015 | 07:36 AM
jsukey's Avatar
Default Tired of the annoying flap flap flap seat belt over 35 mph? No more!!!
Hey guys, so I had finally had enough of the constant flapping of the seatbelts. I also didn't want to worry about anything that would cause them to not retract, once the seatbelt was unfastened. I ended up at Pep Boys, and found the seatbelt shoulder pad. I bought 4 total, 2 for each side...for around $20 I had to remove some of the foam on the inside, in order for the seat belt to move freely. They simply Velcro onto the seatbelt itself. Voila...no more flapping, and they retract normally! Hope this helps free someone else from the torture!!
ID:	613965Click image for larger version
Old Jun 8, 2015 | 09:03 AM
12thman's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=613965"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=613966"/>
One on each side works just as well. FYI
Old Jun 8, 2015 | 10:36 AM
jsukey's Avatar
I started with just 2, but still had a little bit of flapping. I have an '07, so my seatbelt retractor isn't as tight as it used to be.
