What does this mean in English?
Old Jun 7, 2015 | 11:45 AM
GunDude's Avatar
Default What does this mean in English?
ABS codes.
U1418 - Implausible right wheel distance signal received.
C2114 - Dynamics sensor supply voltage low.
My ABS, Traction control lights coming on at start up with chime. Light application of the brake by ABS when starting to roll, then drives normal but no cruise. I have check pretty much everything I can see. Today, I took right rear wheel ABS sensor out and cleaned, took all protective covering off ABS wire as far up to gas tank and check for broken wire, all looked good. I then pulled caliper and check and cleaned with brake cleaner the tone ring.
So, how do I check these codes out?
Old Jun 7, 2015 | 12:53 PM
Rebar-7's Avatar
Try unplugging the wheel speed sensor wires then plug back in, start with the rear ones first.
