Need a 1/2" - 3/4" suspension gain on top of my 2.5" BB with 19/60 springs
I have 2012 JKU with currently a RC 2.5" BB and I also put on 19/60 springs. (p.s. I love these springs. A great improvement over the stock ones and a really good lift to them.) I figuring I have around 3"-3.25" lift total. I do not have any heavy bumpers or winches. I have 35" tires now and at full turn and a little flex I am rubbing slightly. I'm looking for a 1/2" - 3/4" gain to fix this.
Looking for a cheap quick fix until I go for a full 4" spring lift later this year. Do not want a body lift nor do I want to trim and fenders or inner fenders. Would just switching my 2.5" lift spacers to a 3" spacer be a idea? I'm assuming that my 2.5" lift shock and arm extensions and brake line relocation will be enough to cover the extra needed lift??
Thanks in advance.
Thanks in advance.
I'm pretty sure it's the Inner fender. I'll check again after this rain storm rolls thru. I have a stubby stock front bumper.
I'm wondering now if its the crappy plastic skid plate?
You have the clearance for 35s as is. I wouldn't go through the effort for another 3/4" if you're going to swap everything out for 4" coils later on.
At 4" though you're going to need to improve your suspension/steering geometry so budget for that as well.
Good luck.
Good luck.
