Cragar wheel
Old Jun 12, 2015 | 08:01 AM
bullseye15's Avatar
Default Cragar wheel
Hello I'm going to be installing. 2.5" lift and I would like to use a cragar soft 8 or d-window, i believe I cant go smaller than 17" rims so I was thinking a 17x8 but everyone is telling me they won't fit, due to rubbing,Anybody have any input?
Old Jun 12, 2015 | 08:04 AM
bullseye15's Avatar
It's a 2013 jk sport 2 dr
Old Jun 12, 2015 | 10:03 AM
GreatWhite JK's Avatar
Whats the backspacing?
Old Jun 12, 2015 | 10:09 AM
bullseye15's Avatar
Thas as what I don't know, I need to figure out what backs pacing is or need, I was originally trying to put cragars on with no lift
Old Jun 12, 2015 | 10:22 AM
Invest2m4's Avatar
This appears to imply the 17x8 is 4.5" of back space, but the terminology is one I am not familiar with. http://www.cragarwheel.com/images/me...7B3CEB5AA8.pdf
Man, those are really heavy!
Old Jun 12, 2015 | 03:46 PM
MikeRM's Avatar
I have the D window cragar 17 x 8. 2.5 inch lift. 305/70/17 Goodyear mtr. No rubbing ever.
Old Jun 12, 2015 | 04:11 PM
Freedom21's Avatar
I'm running 285's on Cragar Soft 8's. 17x9 with 5" backspacing. No rubbing at all so far.
Old Jun 12, 2015 | 06:27 PM
bullseye15's Avatar
thanks for all the feed back, I was looking to run a thinner tire, so wait....what is the offset I need? would I be able to run the cragars without a lift at all? sorry im a newbie
Old Jun 12, 2015 | 06:46 PM
nthinuf's Avatar
As the tire size increases, you need to move the rim/tire further out. There is a lot of variance in size between different mfg's, so just because someone elses tires that have the same number stamped on the sidewall fit without rubbing, does not mean that yours will. So when you choose a backspace (or offset) err on the side of lower numbers.
For what fits with no lift, a 33x10.50 is the general recommendation with stock flares. With flats, you might fit 35's. With MC's flares, maybe 37's.
Stock backspace is in the 6.25-6.0 range. As that number goes down, the rim moves further out.
If you open the thread stuck right to the top of this modified area, you will find some recommendations. Some people report that they are fine with more backspace than these numbers, but again, tire sizes will vary quite a bit. And lift height. And axle centering. And ...
Offset is another formula to give you the same information, but it uses the rim width in the calculation, so it is not as straight forward as backspace. Use an online calculator to convert offset to backspace. Positive offsets sit further into the wheel wells, negative offsets move the rims further out.
Old Jun 12, 2015 | 07:01 PM
bullseye15's Avatar
wow, Thanks for taking time to reply that, I appreciate it alot
