Rancho vs RK
Old Jun 12, 2015 | 07:52 PM
bookem73's Avatar
Default Rancho vs RK
I need some serious help choosing a lift. I've researched till my head exploded! I have an 07 JKU that I want to put 35's on, this is a DD and I need the wife and kids to be happy getting in and out. I will be mostly mall crawling, with few excursions a year as I'm looking to join a local Jeep club. I had on order the Rancho RS66110B progressive sport lift and a set of RS5000x's but I cancelled the order because it is listed as a 3-3.5" kit. I was planning on getting the LCA brackets, but don't want to open a can of worms with steering and driveshaft issues. I also thought of the RK stock mod because it too is progressive and is listed at 2.5" of lift, which seems less likely to cause steering and driveshaft issues. I'm still leaning towards the rancho because of the rebates!! The kit plus the shocks were going to be under $600 after rebate! That leaves me money towards getting the 35's much sooner. So my questions are if anyone has experience with these, what are some real world lift heights? And would going with the 3-3.5 really cause a lot of headaches later on?
Old Jun 13, 2015 | 01:35 AM
Kojack's Avatar
If you don't have weight on your jeep, bumpers, winch and armour, both will give you more than the listed height. The rock Krawler would not be as high as the rancho you listed. as The rancho would probably net about 4" of lift. This is one of the major issues with picking lifts.....the listed height is a suggestion. But from what I have seen most lift more than the rated lift height.
If you are looking at the rancho, using the drop bracket is a great idea. If you do not disco, then you should be fine with the Drive shafts.
Old Jun 14, 2015 | 03:02 AM
kjeeper10's Avatar
Vet Army
Originally Posted by Kojack
If you don't have weight on your jeep, bumpers, winch and armour, both will give you more than the listed height. The rock Krawler would not be as high as the rancho you listed. as The rancho would probably net about 4" of lift. This is one of the major issues with picking lifts.....the listed height is a suggestion. But from what I have seen most lift more than the rated lift height. If you are looking at the rancho, using the drop bracket is a great idea. If you do not disco, then you should be fine with the Drive shafts.
Agree
Old Jun 14, 2015 | 04:36 AM
DunnyBunny's Avatar
JK-Forum Ambassador
Look at the synergy 2" maybe or even the RK 1.5" lift. I just ran 35s with no lift and flat fenders and it looked and drove awesome.
Old Jun 14, 2015 | 03:03 PM
Lsot's Avatar
Just installed the Rancho 3" Trail System
I gained about 6" in front and 4.5" in back.
No armor, yet.
Old Jun 14, 2015 | 04:21 PM
tarpon4me's Avatar
JK-Forum Ambassador
Holy shitballs batman.
No armor, yet.
Old Jun 14, 2015 | 07:23 PM
bookem73's Avatar
Thats not what I was looking to hear!! I'm starting to think lower might be better, but such a good deal to pass up.
No armor, yet.
Old Jun 14, 2015 | 07:33 PM
5110's Avatar
Just get a teraflex budget boost with shock extensions and call it a day, or flat fenders and 35's. For your needs those will probably be your two best choices and budget friendly. Keep in mind if you go with a 12.50 tire you will need wheel spacers.
Old Jun 14, 2015 | 10:27 PM
nthinuf's Avatar
My first thought was that he was sent the wrong coils or something, haven't seen anyone else posting about that kind of height from Rancho coils. You might also send a PM to their forum rep. They are fairly active and should give you some feedback on it.
Old Jun 15, 2015 | 12:19 PM
Rancho's Avatar
Sponsoring Manufacturer
3" for a 4 door
3.5" for a 2 door
Using the progressive springs pretty spot on to their heights.
You will need to address the exhaust/driveshaft.
If you aren't going "twisty" all over the place your drive shafts will last along time.
Also to the gent who got 6" up front, P/N's on springs by chance?
I run our 4" springs and got a bit closer to 4.5" but no where near 6"....
