2011 havoc instrument dimmer wire
Old Jun 14, 2015 | 07:45 AM
Dale36's Avatar
Default 2011 havoc instrument dimmer wire
Hello Everyone,
Okay, did my research and it seems my wires are colored different. I am wanting to tap into the wire that dims the instrument panel and I read that the hvac wire bundle has a grey and orange wire that can be used. Well mine on my 2011 x does not have a grey and orange wire going to the hvac....or I could be colorblind.
I am just wanting to light up the pressure gauge for my OBA.
Are there other options or does someone know?
Thank you!
Dale
Old Jun 14, 2015 | 07:46 AM
Dale36's Avatar
I HATE auto correct! Sorry about the title...should learn to edit.
Old Jun 14, 2015 | 09:19 AM
lowendrider's Avatar
I ran into the same problem with my '11 trying to wire up an oil pressure gauge. I was told you can get behind the instrument cluster to find the wire you're after. I gave up before finding it, deciding my oil pressure gauge wasn't bright enough at night to bother me.
Old Jun 14, 2015 | 12:35 PM
14Sport's Avatar
You should have an orange wire with gray stripe on the back of the HVAC controls according to Mark.
See post #21 in this thread...
https://www.jk-forum.com/forums/jk-e...6/#post3992346
Have you tried any of these other possibilities detailed in Post #1?
https://www.jk-forum.com/forums/jk-e...lights-311176/
Old Jun 15, 2015 | 05:20 AM
Dale36's Avatar
Thank you for the links! I will check the other locations. In all the locations, it is a grey/orange wire...correct?
Old Jun 15, 2015 | 05:41 AM
14Sport's Avatar
Except for the instrument cluster, where it is the orange wire from the black connector. And it is an orange/gray wire. The predominant color is listed first. Not sure if you were looking for a grey with orange stripe.
Let me know how you make out.
Old Jun 15, 2015 | 12:09 PM
Dale36's Avatar
Nah, just the way I typed it....there is no wire in the 2011 sport hvac that is orange and grey period.
Old Jun 15, 2015 | 12:51 PM
14Sport's Avatar
Okay. Good to know. I updated that thread to show through 2010, since I believe 2011 was when the interior was redesigned. Until I hear differently that is how it will stay. Thanks for the info.
Old Jun 16, 2015 | 09:41 AM
Dale36's Avatar
Found it! Will post in a new thread with correct title
Old Jun 16, 2015 | 10:18 AM
14Sport's Avatar
Awesome. Which one did you end up using?
