Want different center caps
Old Jun 18, 2015 | 12:33 PM
BackinBlack07's Avatar
Default Want different center caps
Hi there,
I've had these wheels on my 07 since it was essentially new. I'd like to go with a lower profile center cap. I've see some of the pop in plastic jeep ones, like picture, but wanted to know if anyone else had experience with something else. These are Ultra wheels.
Thanks!
ID:	615245   Click image for larger version
ID:	615246   Click image for larger version
Old Jun 23, 2015 | 10:51 AM
Camojeep's Avatar
Painted my with Plasti-Dip and they look good, very cheap way to do it. If you change your mind easy to put back to stock.
Old Jun 23, 2015 | 10:57 AM
Invest2m4's Avatar
The cap sizes are usually all different and mount differently. You'd need to find caps that work with your wheels (if there are any). Try the manufacturer, they may have some options.
Old Jun 23, 2015 | 11:24 AM
D_engel's Avatar
I dont think steel wheels will accept any pop in caps. The mounting surface is just too thin and the hub flange will likely get in the way. Id recommend just taking the caps off completely and hitting the hubs with some black paint.
Old Jun 23, 2015 | 03:09 PM
jadmt's Avatar
JK-Forum Ambassador
ditch the center caps altogether. Like was said in the other post just hit the end of the axle with plastidip.
Old Jun 23, 2015 | 03:23 PM
Its-a-JK's Avatar
Posted this in other threads of my steelies that I plastidipped. My Jeep is red byy the way
Old Jun 23, 2015 | 08:27 PM
RoysRig's Avatar
I'm gonna be-dazzle mine.
Old Jun 23, 2015 | 09:32 PM
Yep, I should check with the manufacturer. If that doesn't work out will most likely go the no cap route, thanks
Old Jun 24, 2015 | 10:16 AM
nthinuf's Avatar
https://www.jk-forum.com/forums/jk-w...er-caps-76182/
Old Jun 24, 2015 | 01:22 PM
CarpenterJK07's Avatar
Ive always thought caps on steelies looked out of place. ditch them. Good luck
