rear track bar question
Old Jun 19, 2015 | 07:03 PM
gunbo75's Avatar
Default rear track bar question
Hi all.So i have a teraflex 2.5 coil lift with a 1"puck all around. I have been having trouble with the 3/8 bolt on the rear track bar bracket and the axles not centered anyway so can I just remove the bracket and put the track bar back in the stock position it would probably straighten up the rear end anyway thanks in advance
Old Jun 19, 2015 | 08:14 PM
TheDirtman's Avatar
Do you have a stock track bar?
Raising the axle side mount is what would be recommended. If you are having trouble with a bolt not staying tight you can always weld the bracket to the axle but personally I would remove the factory one and replace it with a heavy duty bracket and mount it so it is in proper alignment with the new lift height you have.
Old Jun 20, 2015 | 06:33 AM
gunbo75's Avatar
Great thanks
