Gangster Lean
Old Jun 22, 2015 | 03:36 PM
Albino Lizard's Avatar
Default Gangster Lean
I came back from the Rubicon and my jeep is leaning pretty good on the passenger side. I know jk's are known to be a little heavy on that side, but this is way past a little. I tried to adjust my coilovers and it only had minimal impact.
Is it possible the rear sway bar is bent?
Thanks in advance.
Old Jun 22, 2015 | 03:42 PM
wittys-jk's Avatar
Is your gas tank full because that usually contributes a bit but it sounds like you have more than the typical full tank lean.
Old Jun 22, 2015 | 03:44 PM
kfast24's Avatar
Check sway bars might have passenger side binding up somewhere easiest check just disconnect and see if lean goes away
Old Jun 22, 2015 | 03:45 PM
Its beyond full tank lean. When I cranked down the rear coilover it raised the whole rear up a bit. I didnt have a problem before the trip.
Old Jun 22, 2015 | 03:52 PM
JayswranglerX's Avatar
Unseat a spring?
Sent from my LG-LS980 using JK-Forum
Old Jun 22, 2015 | 04:02 PM
Originally Posted by JayswranglerX
Unseat a spring? Sent from my LG-LS980 using JK-Forum
Coilovers. Everything is intact.
Old Jun 23, 2015 | 04:21 AM
JE8154's Avatar
Disconnect the sway bar and see if the lean stays. Not rocket surgery
Old Jun 23, 2015 | 06:36 AM
SoK66's Avatar
Mine developed a mysterious lean to driver that turned out to be caused by a twisted Full Traction rear sway bar. Reinstalled the stock rear bar and threw the FT POS in the dumpster. No more lean
Old Jun 23, 2015 | 07:02 AM
Originally Posted by SoK66
Mine developed a mysterious lean to driver that turned out to be caused by a twisted Full Traction rear seat bar. Reinstalled the sticker and threw the FT POS in the dumpster. No more lean
That confirms my suspision. A factory replacement is only $99 bucks. I'll pull off the sway bar and check it out.
