newbie suspension questions
whats up everybody? I have a 2011 2 door jk. im looking to piece together a suspension and it consists of rancho rs999331 and rs999332 long travel adjustable shocks, rubi springs 19's and 60's, 2 inch extended bumpstops, 2 inch coil spacers, quick disconnects, spring retainers, 35" m/t's, 1.5" wheel spacers and cut fenders. oo and possible shock relocation brackets. my questions start with track bars, steering stabilizer and swaybars. they confuse the crap out of me. im coming off an i.f.s. fj cruiser so the set ups are different. so with the suspension set up I have listed what should I do with the track arms, sway bars and steering stabilizer? im on a pretty tight budget. any help ,guidance, ball busting and info would be appreciated.
Relocate your steering stabilizer on top of your tie rod. I nearly ripped mine off. Rancho makes a good cheap stabilizer. You arent lifting that much and you likely wont have any issues with your track bar/axle location.
how much lift do you think I would achieve with this setup? 3-4"'s?
Lift height and shock length/travel are not really related that much. Technically they are to an extreme, but your bumps and coil length extended are more so the determining factor for shocks.
the prices are half decent for the shocks, so I figured for the long run if I did wanna go with a higher lift at least I have the shocks.
judging by your pic, you know how to flex. how does the setup im looking to do sound to you?
I ran 17 collapsed x 29 extended shocks on 35s and cut fenders around 4" lift. I used all of the travel i think i had 2.5" bumps but thats been a long time. Pics are in my build thread somewhere. I did have to move my shock mounts and retain my coils
It's really only lift over where you are now. You'll probably get about 3" from your current setup depending on bumpers etc. But you'll only be 2" taller than a Rubicon. Plenty to clear 35's with cut fenders.
