What suspension lift do I have?
Hey guys and gals.
I bought my JK in January and the guy I bought it from had no idea what was done to it. I know it's lifted, but I can't figure out what has been done after looking at all the cheap lift options. I'm fitting 35s on 4.63" backspaced wheels. I have a Warn full width bumper I just added and it's sagging a lot. It looks like I may have only 2" lift in the front after the bumper. The steering stabilizer is RC, but the springs, shocks, and shock mounts are all stock as far as I can tell. I can't find a spacer kit that seems to fit the bill.
Does anybody have pointers on what to look for?
That's what I was thinking. Since I have an auto, should I consider a 3" lift? I would be counting on the weight of the bumpers and 35" tire on the back to drop that to 2.5 to avoid driveshaft issues.
You shouldn't have any serious drive shaft issues. I have a 3.5" on my JK and have no issues. I did put in exhaust spacers to push the exhaust cross over back to help with additional clearance. If you have a 4 door, the best option is the AFE Y-Pipe - it moves the exhaust cross over behind the transmission cross member.
Most aftermarket coils use higher spring rates and are sized for jeeps with winches and armor. I would stick to one of the "premium" brands in the 2"-2.5" height range to run your size tires. I would be looking into some proper shocks and learn about bump stop set up as well as from the photo yours are not set up correctly and you have less articulation then a factory jeep.
