Front Track Bar for 2.5 " Lift
Just got a Teraflex 2.5" lift and I love it so far. The front axle moved about an inch to the drivers side. I am looking at the rubicon express adjustable track bar RE1673 to center the axle. Any thoughts ?
2007 Jeep JK
2007 Jeep JK
I just measured it with a plumb-bob. The front is shifted to the drivers side by .5" and the rear is shifted to the drivers side by .75". I did not take this measurement before the lift. I am debating if I need to fix it at all?
I doubt you will feel one iota of difference in how it drives so if aesthetically it does not bother you leave. I had about the same and went with a Tera flex bracket in the back and a RK adjustable in front. If I had to do it over I would skip the front but would still do the rear track bar bracket as it does raise the roll center where it should be.
