Switch-Pros SEMA Award Winning SP8100 Switch Panel Power System
Old Jun 28, 2015 | 07:13 PM
SWITCH-PROS's Avatar
Former Vendor
Default Switch-Pros SEMA Award Winning SP8100 Switch Panel Power System
Awarded Best New Interior Accessory Product at the 2014 SEMA Show, the Switch-Pros SP8100 is unlike any other product in the marketplace! Here are just a few key features:
  • 100 amp, all solid state, completely waterproof power module (NO RELAY OR FUSE BOX)
  • Bluetooth interface built in (no additional charge; no additional module to install)
  • 7 switches rated at 18 amps, 1 switch rated at 30 amps
  • User adjustable nighttime backlighting
  • Any or all switches can be programmed as Ignition or Battery Input
  • Switches can be On/Off or Momentary, and can be programmed with memory function
  • Lighting accessories can be programmed to have a Flash or Strobe secondary function
  • A Master Switch can be programmed
  • User selectable switch legends (sheet of 50 included)
  • Built in over-current and over -temperature protection
  • Made in USA
Check out this video for a complete demonstration of how the system works, and call us at 949-581-2991 with questions. To order, call or visit www.switch-pros.com. https://www.youtube.com/watch?v=tXA1eVxxlRM
Old Jun 28, 2015 | 07:46 PM
ShutterBug's Avatar
This thing is pretty cool.
Daystar needs to make a lower dash panel that this can fit into.
Old Jun 29, 2015 | 02:45 AM
GJeep's Avatar
Very nice, 2 more switches than the sPod has, but way overpriced like the sPod is.
Old Jun 29, 2015 | 10:00 AM
Former Vendor
The SP8100 switch panel kit includes a universal bracket for mounting the switch panel. The switch panel can be mounted to the lower dash by the shifter with the bracket.
Old Jun 29, 2015 | 07:38 PM
ameise2015's Avatar
I installed this using the bracket that came with the kit on the lower dash and it looks good.
