Lift and cruise control
Old Jul 2, 2015 | 02:32 PM
heyjunior's Avatar
Default Lift and cruise control
Just installed an AEV spacer lift and now my cruise does not work. Is it a coincidence or could I have damaged something in the process? Suggestions.....2012 rubicon unlimited
Old Jul 2, 2015 | 04:24 PM
jireson's Avatar
Is your traction control or esp light on? If they are it could be a bad wheel speed sensor or the abs.
Old Jul 2, 2015 | 04:33 PM
OH9JK's Avatar
JK-Forum Ambassador
Re center your steering wheel and the cruise control will work again.
Old Jul 3, 2015 | 05:07 AM
heyjunior's Avatar
The traction control light is not on nor is the esp. The wheel is also entered.
Old Jul 3, 2015 | 05:55 AM
jadmt's Avatar
JK-Forum Ambassador
Are you sure it was working prior? the 2" lift is very basic and hard to imagine that it would cause the cruise not to work. I have installed 4 of the 2" lifts in the past year and never an issue and never had to recenter the steering wheel on any of them. I am thinking in the absence of abs or other warning lights it is coincidence. Check the fuse and check to see if the brake pedal is not hanging low for some reason which will kick the cruise off.
Old Jul 5, 2015 | 08:51 AM
heyjunior's Avatar
Looked at the fuses and it was ok, moved the tilt back a new forth and nothing. However today it's working..... Gremlins
Old Jul 11, 2015 | 05:42 PM
heyjunior's Avatar
All is working I must have a short in the switches on the wheel. It seems that when I use the " cancel button the city cruise doesn't work till I bang the wheel till the cruise starts working again. I must need a new switch.
