DuraTrac 255/75R17
Old Jul 16, 2015 | 09:45 AM
JK703's Avatar
Default DuraTrac 255/75R17
Any reason why these tires are so much cheaper than other sizes smaller or even around the same +-1"? DuraTrac 255/75R17
http://www.tirerack.com/tires/tires....7WDT&tab=Specs
Old Jul 16, 2015 | 09:56 AM
the_jeep_now's Avatar
They are P rated tires. Most other ones are LT tires which are usually more expensive. I have these and like them a lot. They are very light compared to other tires and still capable for my use.
Old Jul 16, 2015 | 10:25 AM
JK703's Avatar
What does your "use" consist of?
Old Jul 16, 2015 | 10:36 AM
JK703's Avatar
Also, being that it's P rated, would the softness make it so the tread wears faster? Or does that ONLY apply to the side wall?
Old Jul 16, 2015 | 10:52 AM
PhantomRescue's Avatar
Signifies its primarily used for passenger cars and minivans. The sidewall are typically weaker, where as most LT tires are a little more aggressive tread and have a heavier sidewall rating.
I looked into Duratracs, as I have installed them on many different vehicles, but in that size they're a little weaker because of the 'P' rating.
I just got back from the shop with a new set of Cooper ST Maxx tires as a replacement for my 5 year old BFG Mud-Terrain tires that came on my JK.
If you're mostly on road with a little bit of trail once in awhile, then the P rating is not going to hinder you much. Less weight, better MPG etc......
If you like the trail as much as possible, you're going to want (need) a beefier tire. I went with the 255/75R17 even though my JK is lifted 2.5", it's a smoother ride and turning 35" tires would be too hard on the front end and the wallet.
Old Jul 16, 2015 | 12:47 PM
JK703's Avatar
Thanks for the explanation and opinion. I plan to just put on Rubicon suspension with a leveling kit. Then get some wheel spacers. 95% of my driving is on the road, but a couple times a year I do some mudding and logging roads. I also do a fair amount of snow driving which is why I want the Duratracs. Looks like this might be the route I go. I have 34" Duratracs and 3" spring lift on my 08' and loved them.
Old Jul 16, 2015 | 12:55 PM
OkieM3's Avatar
Yep, you'll want the sidewall thicker than a P tire if you ever offroad. Sharp rock will quickly shred a passenger sidewall.
Old Jul 16, 2015 | 01:41 PM
I use my JK as DD, mostly highway with occasional weekend escape on fire roads. No rock crawling for me so these tires do the job.
Old Jul 20, 2015 | 07:12 AM
JK703's Avatar
So you think the $50 extra per tire (assuming same size @~32", but just LT rated sidewall) would be worth it over the P rated tire?
LT235/80R17 - $212 per
vs.
P-Rated 255/75R17 - $160 per
http://www.tirerack.com/tires/tires....=45-69212208-2
