Rough Country X-Flex Control Arm Joint Rebuild with MetalCloak
Old Jul 16, 2015 | 07:31 PM
wharthog69's Avatar
Default Rough Country X-Flex Control Arm Joint Rebuild with MetalCloak
Folks
I see hints here and there that someone has already done this, I'm hoping somone has some information.
My RC X-Flex Control Arms are needing the joints rebuilt. The kits are cheap enough, but I'm intrigued about using the MetalCloak Duraflex Joints in them instead.
Has anyone done this? Or, does anyone have handy the joint measurements or part numbers so I'd know which parts to buy?
No, I don't expect them to perform like MC Arms, but I can't really justify replacing all 8 of them right now.
Old Jul 17, 2015 | 02:19 AM
Monte417's Avatar
I'm using the new synergy duroflex joints on my frame side rough country front lower control arms. I had to shave them down a bit then pressed in. Not sure about metalcloak though sorry
Old Jul 17, 2015 | 06:54 PM
wharthog69's Avatar
Thanks
I could do those probably as easily. What size did you buy?
Old Jul 18, 2015 | 02:21 PM
Monte417's Avatar
Originally Posted by wharthog69
Thanks I could do those probably as easily. What size did you buy?
Sorry I don't remember the part number but if you call synergy tell them you need the part number for the front lower control arm bushings
