Mactrac lift and Bilstien shocks
I wouldn't be the guinea pig. They do mostly IFS trucks. Even companies making lifts for the JKs for years are still working to improve the design. JKs are unique in the vast range of curb weights. It takes some solid engineering to make coils that work on a 4500lb JK and a 6500lb JK. Not to mention taking into consideration all the other suspension mods a customer may do in the future.
So I should do away with the springs and buy some better ones? I am pretty new to jeeps but I read the bilstein shocks are pretty good. What else am I missing that I should know about the shocks and/or springs?
You should look at a lift from a known manufacturer of JK lifts. I'd also say Bilstein is not a great shock for JKs. Lots of better choices.
If you're not looking to spend much, look at a budget boost.
