issue with Plush Ride Lift JK Coil Springs by EVO MFG
Hi all
after checking jeep forums and reviews I've decided to order Plush Ride Lift JK Coil Springs by EVO MFG and I did it.
before a few days I've installed them on 4 inch teraflex JKU rubicon with fox 2.5 adj bypass shocks.
as soon they are installed the jku is sitting lower on passenger side then decided to change the coils to other side and noticed this time driver side is lower.
can any one of you guys tell me what is the reason of this issue?
we don't have a dealer here for EVO and hopefully this issue be resolved with no extra cost.
went to 2 jeep workshops and both said could be something wrong with coil springs.
I've e-mailed them and still waiting for the reply regarding this issue.
your advice is appreciated
In the right picture you hand is extended or looks to be extended a lot more so than the one on the left.
Can you get a measuring tape out and take a pic of the difference? Have you called EVO and asked?
I'm thinking of the 4 inch plush EVO coils but not if this is an issue.
Op- are you comparing the height of the evo coils against what you had with the Tera flex 4" coils? Or swapping the evo coils from side to side?
Evo does not have designated driver or passenger coils, they are the same coil for the front.
But they do make 3" or 4" coils.
If the problem moves when you change sides would seem to indicate a spring issue. I would document the issue with a tape measure and contact EVO for assistance
