Bent evo flipped draglink.. OPTIONS???
Old Aug 3, 2015 | 02:20 PM
bombout800's Avatar
Default Bent evo flipped draglink.. OPTIONS???
I know it's just a right side drive draglink, but I'm wondering what draglink I can replace it with? Is synergy the only brand? What would bet best best. I don't need anything overbuilt, just something a little more stout.
Old Aug 3, 2015 | 02:37 PM
Maertz's Avatar
Lots go synergy, but theres alot better than that evo shit one. They should have labeled it as an oem part and kept there name off it. I watched one bend on stock tires from a minimal hit. I made my own but i run heims.
Old Aug 3, 2015 | 05:11 PM
bombout800's Avatar
Originally Posted by Maertz
Lots go synergy, but theres alot better than that evo shit one. They should have labeled it as an oem part and kept theres off it. I watched one bend on stock tires from a minimal hit. I made my own but i run heims.
What's the benefit to running heims over a tie rod style joint? I think mine bent literally by bumping a dirt wall with the tire slightly turned. So it basically turned my tire whichever way I had it turned but more of course. I had to straighten the wheel out to get back on top of the drop and I'm assuming that's when it happened. I need something that's not gonna bend. Pm me if you can save me some money hahahah
Old Aug 3, 2015 | 05:14 PM
BuckLisa's Avatar
The EVO is just a right hand drive Mopar draglink. Get a Synergy with 2 greasable long lasting 1 ton rate tres and call it a day.
Old Aug 3, 2015 | 07:33 PM
Maertz's Avatar
Not much benefit to a heim. I guess misalignment in long travel scenarios. And also in my scenario i have tons of spare ones. I wouldnt do what i did for yours even though its dirt cheap, youd have to drill pitman arm and knuckle possibly.
Old Aug 4, 2015 | 11:17 AM
kjeeper10's Avatar
Vet Army
Nooo not a crappy stock DL bending.
X 2 Synergy.
Old Aug 4, 2015 | 03:41 PM
TURTLECON's Avatar
Teraflex also makes a heavy duty draglink, same quality as Synergy.
