Need help with turbo build- Map sensor
Old Aug 5, 2015 | 01:36 PM
Kansan's Avatar
Default Need help with turbo build- Map sensor
Hello all, long time reader of the forum but a first time poster. I know I am new here but I could use your guys help. I am currently building a turbo setup on m 08 JK Rubicon and cannot seem to figure out which Map sensor I need to convert this to a 2 bar map system. I did a ton of searching and no luck so far. I did find some people saying use a map sensor from a 2005 neon turbo car but the connectors are different. I picked up an autozone part number SU13100 and a SU3342. Neither of them fit. Again, the connector on the jeep is a mirror image or reverse the sensor from the turbo cars. I will attach a photo to show what I am referring to. What I need is a MAP sensor part number off of somebody's boosted 2008 jk so I can hunt down the sensor I need or an idea of what sensor will work. If there are other options like splicing in a gm 2 bar map I am willing to do that as well. Thanks for all your help!
-James
