Tonneau cover with soft top installed
Old Aug 7, 2015 | 11:16 AM
bryanwithawhy's Avatar
Default Tonneau cover with soft top installed
I need a recommendation here guys.
I want a tonneau cover for the back of the jeep because I usually go top down unless it's raining and don't usually have back seats.
Problem is I still want to have my factory soft top attached to the vehicle. Does anyone make anything that would do the job?
Old Aug 7, 2015 | 12:32 PM
westchester's Avatar
Bestop deck cover Duster, Quadratec # 11154 02305 07 Here's an old photo of my 4-door with Duster and folded soft-top. You can only secure one or other in the rear channel rails, either the duster or the soft top corner sails. For soft-top up, I pull the duster corners off, and secure the sail corners.
Old Aug 8, 2015 | 03:46 AM
Install instructions for the 2 doors say you need to remove the soft top hardware -.- Would be perfect too
Old Aug 8, 2015 | 04:35 AM
RubiKing's Avatar
Won't work with a two door because the soft too hardware goes above and below the aide channel.
Old Aug 8, 2015 | 06:22 AM
Well my hope was that someone made one that goes just front and back and doesn't actually clip int the channel
Old Aug 8, 2015 | 05:16 PM
'11BronzeStar70th's Avatar
Bryan - Do a search on this site for "self-designed lace-in tonneau cover". I designed and had one made for my JKU for the same reason... I couldn't find a cover that could be used over the bed while the soft top was installed. I can send you the design if you want to see about modifying or having one made yourself.
