1.5" - 2.5" coil lift on 2015 JKUR
Old Aug 10, 2015 | 04:13 PM
Bushfam5's Avatar
Default 1.5" - 2.5" coil lift on 2015 JKUR
Looking for a good 1.5 - 2.5" coil lift that will level the jeep out and keep the stock ride/handling. I plan on running the stock tires and wheels with a 1.5" spacer. Would RK's progressive rate springs be best or Teraflex's springs or another manufacturer?
Thanks
Old Aug 10, 2015 | 05:46 PM
RubiKing's Avatar
I am looking into the Evo leveling kit. Maybe someone who has that kit can chime in?
Old Aug 10, 2015 | 08:27 PM
juanburgundy's Avatar
I'm considering the EVO as well. Haven't come across any posts on it yet.
Old Aug 11, 2015 | 04:39 PM
mikeJKUR's Avatar
I have the rock krawler 1.5 lift. With the hard top on it sets level. I also have a winch and bumper in the front, stock Rubicon tires with after market wheels.
Old Aug 11, 2015 | 05:36 PM
jadmt's Avatar
JK-Forum Ambassador
I have had tf 1.5" performance coils, 1.5 RK triple rates and rk 2.5" triple rates all in a short period and all 3 are better then stock on my 14 jkur that had 18/60 coils.
2.5 RK will look kind of tall with stock tires. I just ran Ouray area and put on some ko2 34's for the trip as I wanted to save my toyo 35's for an up coming Rubicon trip and I thought it looked funny and they are taller then stock by about an inch and half. stock rims with 1.5" spidertrax
with 35's
Old Aug 11, 2015 | 10:23 PM
Bushfam5's Avatar
Is the triple rate springs of RK better springs than the TF? I noticed the RK stock mod kit provides front track at and rear trackbar bracket while TF seems to provide none of that. Are they needed with this small,of a lift?
Thanks again
Old Aug 11, 2015 | 10:34 PM
mds22's Avatar
this is hands down your best ride quality for that size lift. Add ranchos adj shocks to the plush coils and you will not find a better riding jeep. For less than $250 you will have plenty of money for other mods
Old Aug 12, 2015 | 04:40 AM
jadmt's Avatar
JK-Forum Ambassador
Thanks again
Not needed with 1.5" lift the tf gives 2" in front 1" in back. And not enough axle shift to warrant track bar. TF has a nicer rear track bar bracket as its axle side mounted. They both ride great.
