JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Need advice on tire/wheel combo.... HELP
Old Aug 12, 2015 | 01:26 PM
ShadowTX's Avatar
Default Need advice on tire/wheel combo.... HELP
I'm wanting to run 33x12.50-17 tires with a 2.5" lift on my '07 Sahara JKU...
Wheels I like are the ProComp 7005 @ 17x9... (backspacing is 4.75").
Am I looking at any problems with this setup?
Old Aug 17, 2015 | 01:11 AM
p90Ed's Avatar
I'm running that combo on a stock '13 JKU Sahara with no issues. With your lift you should be fine. I'm going with a 2" lift in a few months but not because it's needed.
Old Aug 17, 2015 | 03:23 AM
buckeyedolfan's Avatar
You can run 35" tire's with that set up.
Old Aug 18, 2015 | 07:48 PM
ShadowTX's Avatar
I was told that but I wanna keep the gas mileage.
Its my daily driver and its 65+ miles to work...
Old Aug 18, 2015 | 09:03 PM
Albino Lizard's Avatar
Originally Posted by ShadowTX
I was told that but I wanna keep the gas mileage. Its my daily driver and its 65+ miles to work...
I'm not sure good gas mileage is why people buy jeeps. You need to dial up your badass. Go 35's!
Old Aug 20, 2015 | 12:10 PM
epleeds's Avatar
I have 35's on mine and average 16 mpg which I don't think is that bad considering the lift/tires. Running duratrac's
Old Aug 24, 2015 | 12:04 PM
JBurner's Avatar
Got 35" yoko geolanders on a 2.5" lift and I still get 16mpg. Go Big
Old Aug 29, 2015 | 04:43 PM
3min3m2's Avatar
37s, 3.73s, 3.5 lift. 16-17mpg
Old Oct 30, 2015 | 10:16 AM
Torched03Mach's Avatar
From everything I've read, I don't see any issues. I'm looking to run a very similar setup.
Old Oct 30, 2015 | 07:59 PM
tjkamp's Avatar
I just put on 35x12.50 MTR K's and a 2.5 lift. Running Method NV's 17x8.5 4.75in back space, with no rubbing lock to lock (haven't flexed it out, but i don't foresee any problems.
With a 2013 running a manual, 4.10 gears, and 35's I'm averaging 18mpg across the first 500 miles (before the lift and tires it fluctuated between 17 and 21) I drive a lot of flat land around Houston and the gulf shore states.
Happy Jeeping!
