Help stock spare tire carrier with 35
Old Aug 15, 2015 | 03:56 PM
weekendjeep's Avatar
Default Help stock spare tire carrier with 35
I wanted to find out what mod you guys are doing. I went to a 35 on my stock wheel and 3rd. Brake light is in the way.
Thanks
Old Aug 15, 2015 | 06:43 PM
Trev8955's Avatar
I went with the Smittybilt SRC Oversized Tire Carrier. It's strong and sturdy enough and I like that I can lock it easily. Cost $130 on Amazon and was easy to install. No bad rattle unlike before without it. One day I'll have a bumper tire carrier combo but till then it's cool. Welcome to the 35" club! :rockon:
Old Aug 16, 2015 | 04:38 AM
Thanks for the info. I'm trying to keep this Jeep more tame.
Old Aug 16, 2015 | 04:49 AM
karls10jk's Avatar
You'll get a few different responses but please be aware that the stock carrier has cracked in the past on a new jeep with a stock sized spare.
You can do the teraflex hinge and carrier to keep a relatively "tame" look while also handling the tire without worries of damaging the tailgate or cracking the carrier.
That didn't answer your question though. You can buy a third brake light relocation kit or cut the brake light off and buy the lug nut light kit. It's $35 or you can piece it together for under half of that.
Old Aug 16, 2015 | 05:12 AM
TheDirtman's Avatar
Delete the spare and buy a plug kit and on board air.
Old Aug 16, 2015 | 07:50 AM
chemlight_ninja's Avatar
I cut the third brake light off, tucked the wires into the vent back there and zip tied them.
Old Aug 16, 2015 | 08:11 AM
Terraflex is saying that it will only work with a 32" tire ? Does it work with a 35 ? How could I raise the 3 rd. brake light , to keep factory look ?
Thank you
Old Aug 16, 2015 | 08:23 AM
Broncorif's Avatar
My brake light worked fine with 35" BFG M/T on Teraflex Carrier.
Old Aug 16, 2015 | 10:05 AM
Thanks for your reply. Jc Whitney sells it. Got a code for 20% off today.
Old Aug 16, 2015 | 04:10 PM
Fiveofun's Avatar
Are you running stock wheels? I have the Teraflex HD carrier and had 315/70/17's on AEV Pintlers and the factory 3rd brake light was not in the way
