Change R&P when installing an ARB locker?
Old Aug 19, 2015 | 01:04 PM
jedg's Avatar
Vet Army
Default Change R&P when installing an ARB locker?
Okay. So this is a newb question, but I haven't found the answer.
I'm looking at the possibility of swapping 1 tons into my JK. Part of that is pricing it so I can budget for it. While looking at the axle options I see that many of them are 4.30 gears. I run 4.10 now and like it. SO, when taking these axles to lockers, can I reuse the 4.30 R&P with the ARB locker?
Old Aug 19, 2015 | 01:20 PM
GreatWhite JK's Avatar
What axles are you looking at? In most cases, you can buy a arb locker for 4.10 and down and 4.56 and up.
Old Aug 19, 2015 | 01:27 PM
jedg's Avatar
Vet Army
2005+ F350. Front and rear.
I haven't found anything a that says one way or the other.
Old Aug 19, 2015 | 02:11 PM
JKBud's Avatar
Originally Posted by jedg
2005+ F350. Front and rear. I haven't found anything a that says one way or the other.
I would only run stock gears until your budget allows. No sense in doing it twice. More importantly there's a big weight difference between those and stock axles so that's something you must account for. I assume with those axles you plan on running 37+ tires so more gear will be needed regardless. Unless you have a v8 you're better off going with a deeper gear. Check out invest's build but give some more details about what you intend to do tire size etc. so we have a better idea.
Old Aug 19, 2015 | 02:22 PM
jedg's Avatar
Vet Army
Originally Posted by JKBud
I wouldn't stick with 4:10s especially if you throw a locker in cause you might as well upgrade while they're apart. If budget is a concern run them with the gears in them till your budget allows. Also there's a big weight difference between those and stock axles so you gotta account for that. I assume with those axles you plan on running 37+ tires so more gear will help regardless. Unless you have a v8 you're better off going with a deeper gear.
Well. That's just it. I have a 6.0 L96 with a 6L80E. The 4.10 with 35's is great. It's a good mix for me. No complaints crawling it and great as a DD. My worry is the OEM axles. If the best answer is purchase R&P with the lockers then that's what I'll do. I want to know rather than guess and throw money at not knowing.
Old Aug 19, 2015 | 02:29 PM
JE8154's Avatar
are you planning on staying on 35's? If not what tire size are you going to end up on?
Old Aug 19, 2015 | 02:41 PM
JKBud's Avatar
Now knowing that I can see where your coming from. Your best bet is calling arb or reputable vendor that sells them directly to find out for sure.
