Front axle ?
Old Aug 21, 2015 | 03:00 PM
texastraveler's Avatar
Default Front axle ?
Just bought my second jk this week traded my 08 for a 12... The 12 has a small lift, although everything appears stock other than rubicon express shocks. Just looking under the jeep the front control arms appear to be adjustable? Is this a feature of the newer models or am I looking at this wrong?
Old Aug 21, 2015 | 03:03 PM
Croce's Avatar
Looks like a stock control arm and stock mount to me. Its not adjustable, but you can cut open the control arm hole to adjust the caster (which i highly recommend against doing)
Old Aug 21, 2015 | 03:04 PM
Invest2m4's Avatar
Originally Posted by Croce
Looks like a stock control arm mount to me. Its not adjustable, but you can cut open the control arm hole to adjust the caster (which i highly recommend against)
Also known as cam adjusters.
Old Aug 21, 2015 | 03:05 PM
Croce's Avatar
Thanks! i couldnt think of the technical term for that
Old Aug 21, 2015 | 03:13 PM
Ok, just looking at it quickly it looked like behind the but that the hole in the bracket was rectangular like you had some adjustment...
Old Aug 21, 2015 | 03:15 PM
behind the "NUT"
Old Aug 21, 2015 | 03:29 PM
One more question... Does anyone know if rubicon express lifts used could that were black in color at anytime? Because just looking at the JK it looks like a coil lift but could are black like stock but it has RE shocks and the rear track bar has an adjustment bracket..
Old Aug 21, 2015 | 03:30 PM
Damn auto spell, meant to ask if RE coils were ever black?
