Teraflex 2.5" Coil Lift question
How bad is it that I installed and torqued the rear track bar BEFORE installing the lift on the front end?
I didn't read the directions ALL the way through and thought they just forgot about the rear track bar.
do I need to loosen it after the front is done and retorque? or is it ok?
Thanks.
Thanks.
As long as you put your rear coils in first and put the tires on and the jeep on the ground your good. Also not a bad idea to loosen your control arms with the jeep on the ground, and bounce it a few times, then retorque the control arms. This way the rubber bushings won't be in a bind at ride height.
