Questions about front brake relo brackets
In prep for my 2.5 Rubicon Express lift, i've installed a couple of relo brackets for the rear, and also for the front brakes ( front is highlighted in green in the following pics), question is, should i also remove that lower bracket assembly (highlighted in red/yellow) like for example AEV or RK do with their setups? or should i leave the lower brackets in there because the brake line will have enough slack with the relo brackets in place ?
Thanks a lot
20150822_120931_20606089938_o by SilverFJ RSM, on Flickr
20150822_120819_20801113401_o by SilverFJ RSM, on Flickr
Thanks a lot
