Fuel Hostage/Hubcentric
Old Aug 31, 2015 | 11:12 AM
NJBlackBetty's Avatar
When doing a tire rotation (still sitting here) today the guy pointed out only two of my tires had Hubcentric rings and one wasn't even inside the hub, but was sitting loose. I never experienced any shaking before and hope not to when I leave here. Are these necessary? And if so, where can I get another set?
I have 18' wheels on Nitto Trail Grapplers
Old Aug 31, 2015 | 12:09 PM
Just took it back out on the Turnpike and got her up to 75-80 with no issues.
I see the hub rings are cheap and I'm guessing pretty easy to put on with a rubber mallet. I have a 10 month old and want to be as safe as possible. Let me know what you guys think.
Old Aug 31, 2015 | 12:13 PM
kfast24's Avatar
Are they for backspacing like the spidertrax spacer? If not toss them if they are just limiting the amount of thread on your lugs. Nothing wrong with proper spacers but the ones that looks like washers shouldn't be trusted
Old Aug 31, 2015 | 12:44 PM
Not for backspacing. I believe they are so the weight of the Jeep doesn't rest solely on the lugs, but rather the hubs.
Old Aug 31, 2015 | 08:41 PM
Buuuuuuuuuump
Old Aug 31, 2015 | 09:07 PM
fredrok's Avatar
The only hub-centric mainstream wheels that I know of are AEV and stock. Almost every other aftermarket wheel is lug-centric so if one wanted to be real particular about it, they could get hub-centric rings to make it so. But I've not seen a rash (or any) of lug-centric wheels breaking lugs off, so I would just toss the rings you have that don't fit properly and ride on.
Old Aug 31, 2015 | 09:10 PM
LoneWolf's Avatar
Originally Posted by fredrok
The only hub-centric mainstream wheels that I know of are AEV and stock. Almost every other wheel is lug-centric so if one wanted to be real particular about it, they could get hub-centric rings to make it so. But I've not seen a rash of lug-centric wheels breaking lugs off and almost all aftermarkets are, so I would just toss the rings you have that don't fit properly and ride on.
AEV wheels are no longer hub-centric. There's a post from Dave about it on the AEV forums. The only aftermarket supplier I'm aware of making hub-centric wheels now is Rugged Ridge.
Sent via Jeep wave from my NSA-approved domestic-espionage device.
Old Aug 31, 2015 | 09:11 PM
fredrok's Avatar
Ah, well, there ya go. Even less reason to worry about the rings.
Old Aug 31, 2015 | 09:18 PM
I don't have AEV wheels. I have Fuel Hostages. 18x9. I found their bore measures 87.1. Just trying to find what a 2011 JK Sports hub size is.
Old Aug 31, 2015 | 09:20 PM
I'm just trying to be a little more careful especially because of the kid.
