Quiet exchaust options?
Old Sep 2, 2015 | 05:14 PM
jknit's Avatar
Default Quiet exchaust options?
I know this is counterintuitive because most people are looking for sound. I had a dynomax dual exhaust on my last JK. I want to increase the flow and help out with some of the pedal lag on my 2015, but have no interest in a loud exhaust anymore. Just seeing if there are any quiet performance exhaust options out there
Old Sep 2, 2015 | 06:48 PM
karls10jk's Avatar
I'm curious too, though we may be a quiet minority. The increased flow helps with hp when some of us could really benefit from a little more torque (more restricted pipe...to an extent)
Old Sep 2, 2015 | 08:18 PM
rsmwrangler's Avatar
A muffler change won't do much for performance, though when i removed mine, i could've swore she felt more peppier, I went with a Magnaflow muffler, and had my local muffler shop do the welding job, that setup was fairly quiet, barely louder than stock, so mellow that i had the factory resonator deleted as i was actually looking for a tad more noise, and while it makes more noise than stock, it's not obnoxiously loud the way it is, even with the res deleted.
Old Sep 2, 2015 | 09:08 PM
LidLess07X's Avatar
If you have an otherwise stock JK, just replace it with a stock muffler. Aftermarket exhausts on these JK 's don't do squat.
Old Sep 3, 2015 | 12:37 AM
foxsat71's Avatar
I agree 100%. I had to remove my stock muffler due to the coilovers. I drove around w/o it for a couple of weeks - horrible raspy sound. Kept the resonator and most of the stock pipe and added a universal MagnaFlow 22" free flow muffler. Now it's perfect.
Old Sep 3, 2015 | 01:27 AM
Mark Doiron's Avatar
Please don't put advertising in my posts that look like it's something I endorsed. I did not endorse that Banks Power ad that popped up in my post--I have no opinion about it because I have no experience with it. I understand JK-Forum needs to make money from advertising, but don't make it look like it's me promoting the product, please. A line demarking the ad from my own post would suffice. I have deleted my own comments, which offered what I considered good advice and info for OP.
Old Sep 3, 2015 | 07:32 AM
jadmt's Avatar
JK-Forum Ambassador
it is frustrating as the ads are so freaking big you can not find the actual post some times.
Old Sep 3, 2015 | 07:43 AM
Zroe's Avatar
I ran the exhaust from Dominion Off-road. It's quiet, probably exactly what your looking for. Much quieter than the MBRP that o had before.
Old Sep 3, 2015 | 06:33 PM
MagnaFlow's Avatar
Former Vendor
Thanks! This is pretty much what we're known for, for the most part, though some of our off-road and competition/racing cat-backs can be pretty loud. Our typical street systems and universal mufflers do a good job of absorbing sound at idle and cruise but adding significant volume as you open the throttle. When quiet or loud, though, you get a nice, smooth deep tone regardless.
But the key point for the OP was wanting a livable volume with improved flow. Our universal mufflers are all straight-through with a perforated core, which means improved exhaust velocity and more power. Power gains from an entire cat-back exhaust top out around 10 percent (and that's typically high-power applications) so a muffler probably won't add gobs of power, but sometimes an extra pony or two in the powerband can make just-enough difference.
Old Sep 15, 2015 | 04:40 AM
speedlimit's Avatar
Hi,
That should not be happening if you are logged in. If it happens again, please take a screen shot of the ad, I'll get it removed. Thanks!
Bob
