Height of JK after lift/tires
Those of us that have overhead clearance restrictions (home garage, carport, work garage, etc...) have to consider the impact of what we are purchasing to make sure we aren't too tall. Help us out by listing your suspension and tire combo and your JK's overall height at the highest point. Make sure you mention how much tread you have left on your tires.
Mine: stock suspension, stock Goodyear Wrangler RSA 255/75R17 tires with 50% tread, 71-3/4"
Thanks!
Thanks!
There is already at least one of these threads on here.. If you want accuracy in measurements to compare you better also list every other thing you have done to the jeep that may affect weight as that has more of an affect then the % of tire tread you have. The results would be endless and really serve nobody.
