Poison Spyder Rock Brawler - Tire carrier sagging
Old Sep 6, 2015 | 06:13 PM
scooby snacks's Avatar
Default Poison Spyder Rock Brawler - Tire carrier sagging
Hello, I have a Poison Spyder Rocker Brawler and the tire carrier is sagging, meaning I have to lift the tire carrier to clear the bumper. I have loosened everything and put my high-lift jack on the carrier raising it and then tightened everything back up. I still end up with the sagging. Is feels like there is play in the hinge barrel. It feels like the tire carrier has about a 1/4" of play up and down. Any ideas on how to fix or adjust this??
Old Sep 6, 2015 | 06:26 PM
Da20captain's Avatar
Check the bearings and then tighten the nut at the hinge. I have the same tire carrier and never a sagging issue.
Old Sep 6, 2015 | 06:28 PM
Freaking cap is on tight... got to figure out how to get it off... lol
Old Sep 6, 2015 | 06:31 PM
Use a set of channel locks if you have any or a super large wrench. I used channels ka and mangled mine a little. You could maybe wrap the cover best you can before applying the channel locks. You have a rubber glove maybe put that on and try to loosen the cover by hand.
Old Sep 6, 2015 | 06:34 PM
Another thing I did was go to a boat dealer and got a thicker rubber O-ring to replace that pos one they give you. Seems like it keeps moisture out better than the thin one.
Old Sep 6, 2015 | 06:39 PM
I'll give it a shot... brb
Old Sep 6, 2015 | 06:48 PM
Okay, my wrench wasn't big enough. The instructions say you can use a 2-12". I assume they mean a 2-1/2" socket. Guess I'll make a trip to the auto parts store in the AM.
Old Sep 7, 2015 | 04:54 AM
holaCG's Avatar
I bought a 24" Olympia crescent wrench off Amazon for less than $30 to my door. I saw that poison spyder is now shipping a laser cut wrench with new bumpers so you might want to give them a ring and they would send one out. Good luck!!
Below is my son holding the little baby crescent wrench!!
Old Sep 7, 2015 | 06:12 AM
I soaked the thing in PB rust blast and used I used a big pipe wrench and a set of channel locs and the freaking thing won't budge. Trust me, I man handled it...
I'm at a loss at the moment... any ideas??
Old Sep 7, 2015 | 08:21 AM
Let the PB Blaster soak for a while maybe it will free it up. When you get it off maybe apply some anti seize. You have me nervous now I may see if I should maybe check out my cover to see if I am gonna have the same issue. I hope not, I put a much thicker O-ring to assist with keeping moisture out.
I am out of the country at the moment but should be back in a couple days, but I would be glad to help you out when I get back if you don't have it squared away by then.
