4inch lift with Duratrac 315s
Old Sep 12, 2015 | 12:55 PM
605jeep's Avatar
Default 4inch lift with Duratrac 315s
Anyone run this? I am also considering bushwackers but not sure if it is too much lift. If you do, how tall does your jeep sit. I am considering doing that exact setup but dont know if it would fit in my garage.
Thanks
Old Sep 12, 2015 | 01:03 PM
Mark Doiron's Avatar
Welcome to JKF!
Plenty of folks running 35s with 2.5" lifts. 4" will incur additional mods, and with limited benefits. Suggest you find Dirtman's excellent FAQ "My Thoughts on Lifts" in the stickies on this sub-forum.
BTW: I run 315 Duratracs with 2.5" lift and stock fenders. Check out my videos at DigitalByDoiron on YouTube to see how that works for me (along with a lot of friends running 35s/2.5".
Old Sep 12, 2015 | 01:41 PM
nthinuf's Avatar
Yep, that's a lot of lift, especially if you are going to run flats. If you go down to JK Show & Tell, you will find some huge picture threads with just about any combination of lift and tire size you could want.
Or use this string in google or whatever search engine, followed by what you want to find:
site:www.jk-forum.com
site:www.jk-forum.com 4" 35's
For the total height, it will vary by build. The specific lift mfg, coil/spacer, rim size, top choice, added weight, whatever else. Too many variables, so just measure yours and do some simple math. Assume the 4" coils actually give 4", and you are moving from 32's that measure 31" to 35's that measure 34". 3" height increase gives 1.5" lift to the frame/body. 4" + 1.5" = 5.5" taller.
Old Sep 12, 2015 | 04:41 PM
m4belisle's Avatar
Thanks
don't have a 4" lift, but I do have a 2.5" with 315 duratracs and also bushwacker flats. this should give you an idea of if you want to go any higher than the 2.5" lift.
this photo shows a comparison to a stock height JK.......mine is 4.5" taller than the stock one.
if you do go with a 4" lift, you may want to consider 37" tires as the gap between fender an tire will be substantial.
Old Sep 12, 2015 | 04:56 PM
WillysWheeler's Avatar
I am running AEV 2.5" DualSport XT Suspension with AEV Geometry Correction Front Control Arm Drop Brackets and Spidertrax Black 1.5” Spacers with Factory Willys Wheeler 17” Wheels and Goodyear Wrangler DuraTrac 315/70/R17 Tires. I gained 3.5" from my factory Willys/Rubicon Suspension. That is with ARB Deluxe Front Bull Bumper and Smittybilt X2O-10K Waterproof Synthetic Rope Winch which weigh over 180lbs. The rear I have ARB Rear Bumper with Tire Carrier and tire/wheel and weigh over 195lbs. AEV lifts have a rake about 1/2" and stock factory rake was 3/4". My suspension has not sag and almost level.
ID:	624375Click image for larger version
ID:	624376Click image for larger version
Old Sep 13, 2015 | 04:00 AM
BeachJK's Avatar
Anyone run this? I am also considering bushwackers but not sure if it is too much lift. If you do, how tall does your jeep sit. I am considering doing that exact setup but dont know if it would fit in my garage. Thanks
Your thread got thigh jacked. You just want to know if it will fit in the garage.
I didn't have that setup but I did have a RK 3.5 with 37s and it squeezed in the garage. I did also have a Bestop NX so that gave me a little more clearance.
Old Sep 13, 2015 | 05:05 AM
Some of us took "not sure if it will be too much lift" to mean he was wavering on whether he needed that for 35s at all since he didn't write "not sure if it will be too much lift to fit in my garage". But, I can see how it could be taken either way.
Old Sep 13, 2015 | 06:16 AM
TheDirtman's Avatar
I guess the important thing that is missing here is how tall the garage door is.
Old Sep 13, 2015 | 01:40 PM
m4belisle's Avatar
didn't mean to hijack......my setup clears my garage door by 11" but only clears the bracket for the garage door opener by 5"
