Adj control arm setting?
Old Sep 13, 2015 | 08:09 AM
BossierCity_Jk's Avatar
Default Adj control arm setting?
Hello quick question I'm trying to install my adj control arm in the front I have rear upper already and just got front lower. What the idea range for a 4inch suspension. Keep in mind I have a control arm drop bracket
Old Sep 13, 2015 | 09:04 AM
rsmwrangler's Avatar
What do you mean with ideal range ?
Old Sep 13, 2015 | 09:07 AM
sa29560's Avatar
Lose the bracket first. Seems ideal for about 23" to 23.125".
I'm running 23.125" on both left and right.
Old Sep 13, 2015 | 09:20 AM
nthinuf's Avatar
Whatever length it takes to get you in the 4-5 degree caster range. If it's a bit flighty, lengthen them another turn. If you get some vibes, shorten them a bit.
Old Sep 13, 2015 | 10:48 AM
I know the whole reason for adj control arm are to set the caster angle what is the idea caster angle?
I meant like what is the idea length bolt to bolt on the front lower adj control arm when you only got the front lower.
Old Sep 13, 2015 | 10:49 AM
Originally Posted by sa29560
Lose the bracket first. Seems ideal for about 23" to 23.125". I'm running 23.125" on both left and right.
awesome I was wondering if I should lose the drop bracket, I just didn't know if it would ride better with the drop bracket and then both upper and lower arms at 4inch
Old Sep 13, 2015 | 11:56 AM
nthinuf's Avatar
You don't need both. But no harm in running brackets and adj arms. Gives you more fine tuning for the caster/pinion.
The brackets will drop the angles of the arms, making them more parallel to the frame. In theory, this improves handling/cornering/nose diving/whatever.
Old Sep 13, 2015 | 01:07 PM
drexelsteve's Avatar
With a 4" lift I found I had to add so much castor to prevent vibs that my front coils bowed enough to contact the sway bar links. Of course this was with a cv shaft, with the factory shaft you'll be fine with much less castor but you won't be able to flex on a curb without hitting the exhaust. What's your setup?
Old Sep 13, 2015 | 05:07 PM
Factory drive shafts, 3.5 skyjacker and .75 spacer because winch and bumper. My spring touches the sway bar all I have in there now is the control arm drop bracket.
I have been thinking of removing it and inning just running upper and kier arms
Old Sep 14, 2015 | 01:48 PM
SoK66's Avatar
Originally Posted by BossierCity_Jk
I know the whole reason for adj control arm are to set the caster angle what is the idea caster angle? I meant like what is the idea length bolt to bolt on the front lower adj control arm when you only got the front lower.
The front & rear lower control arms cents the axles in the wheel houses and align the bump stops. The uppers set caster/pinion angle in front and pinion angle in the rear. If you do the front lowers only the setting is a bit longer than if you do both lowers and uppers, but not by much. Best rule of thumb, set them to 23 1/8" to start, have the caster checked and adjust a bit to get the best compromise between caster & pinion angle that delivers good steering an no front driveline vibration. With a 4" lift and short arms I ran them at 23 1/4" with 5 degrees caster. I have manual hubs, so the DL vibe issue was moot.
