Front spacer
Old Sep 18, 2015 | 11:54 AM
warrenschandler's Avatar
Default Front spacer
Ended up with a 1&3/4 leveling kit. I'm not sure if it needs that much after doing some measurements. Can someone tell me if I should find a 3/4 or 1" to level front up.
Old Sep 18, 2015 | 04:01 PM
BlackRockBurner's Avatar
Should post under Modified section. So, 1" pucks in front and 3/4" pucks in rear? Plan on bumpers, winch? Do you have recovery gear? When all those are accounted, then figure how much in front to level the rake.
Tires: probably the next thing you will look at. You can run skinny 33" with a possible steer stop adjustment-or- 33x12.5" with quality wheel spacers.
