Which valve? Fumoto or EZ Oil Drain
Old Sep 22, 2015 | 08:16 AM
MAG00's Avatar
Default Which valve? Fumoto or EZ Oil Drain
Ok. I've searched and read several threads on the fumoto and ez oil drain valves. However, I would like to get some input as follows:
1. Is there anything that would put one valve over the other as far as features, construction, quality, etc.
2. Is there any reason to not install one? I have JCR skids so it should be protected.
3. If you chose one over the other...why?
Thanks.
Old Sep 22, 2015 | 09:24 AM
Sirb's Avatar
I don't know about the EZ, but I've had the fumoto f106s for about 1.5 years and I'm a fan. Warm up the engine, short length of tube, and quick oil drain straight into my old 5-quart jug for recycling. No issues so far with the seal or valve; put one on my wife's commuter with no issues there either.
Old Sep 22, 2015 | 09:37 AM
Biginboca's Avatar
I went fumoto only because I've had a couple on several rigs previously and never had an issue. I have the EVO protek skids and it's a perfect combo the valve is protected and still easily accessible for hooking up my hose for draining the oil.
