Gas tank filler neck
Old Sep 22, 2015 | 06:02 PM
Jonny K's JK's Avatar
So went to fuel up before going to AC/DC concert, I never go to full serve but this makes the story better. I'm checking the oil and hear the sound of a waterfall, the person filling my jeep looks at me confused, I look under the jeep and see gallons of fuel pouring out!!! Ummm, I think that's good! I shout as she keeps pumping, so $13 later I look underneath and see a broken white plastic nipple attached to my filler neck but not so well to the tank... Also a broken vent fitting and a broken sensor or something above my rear locker connection. Click image for larger version
ID:	625136 Click image for larger version
ID:	625137 Click image for larger version
ID:	625138 Appears I should have moved the e-brake lines below the cross member and also not have gone wheeling in the mud. Scared to think how much water is in the tank since I took it to the car wash. Dodge says I have to buy a new tank $1300, 4Wheelparts $980, I've put a bungee cord on it and covered it in AB epoxy putty. Anyone else had any luck getting the fittings for full nipple and evap? And what the hell is that broken electric piece above my locker wires? Thanks again Jeeples!!
Edit: had enough fuel to make it to the concert, ran pretty rough after the low fuel light came on, fueled up and didn't loose any fuel, runs better with a full tank and the concert was FREAKING AMAZING!!!!
if you can read this, my Jeep is broken....
Old Sep 22, 2015 | 06:54 PM
davids2011jk's Avatar
Originally Posted by Jonny K's JK
So went to fuel up before going to AC/DC concert, I never go to full serve but this makes the story better. I'm checking the oil and hear the sound of a waterfall, the person filling my jeep looks at me confused, I look under the jeep and see gallons of fuel pouring out!!! Ummm, I think that's good! I shout as she keeps pumping, so $13 later I look underneath and see a broken white plastic nipple attached to my filler neck but not so well to the tank... Also a broken vent fitting and a broken sensor or something above my rear locker connection. Attachment 625136 Attachment 625137 Attachment 625138 Appears I should have moved the e-brake lines below the cross member and also not have gone wheeling in the mud. Scared to think how much water is in the tank since I took it to the car wash. Dodge says I have to buy a new tank $1300, 4Wheelparts $980, I've put a bungee cord on it and covered it in AB epoxy putty. Anyone else had any luck getting the fittings for full nipple and evap? And what the hell is that broken electric piece above my locker wires? Thanks again Jeeples!!
Attachment 625139
broken electrical plug looks to be either the actuator for the locker or the locker sensor.
Old Sep 22, 2015 | 07:00 PM
part 31 or 32
Dana Model 44 Rear Axle for Jeep Wrangler JK at Morris 4x4 Center
Old Sep 23, 2015 | 03:54 AM
Invest2m4's Avatar
Yeah, bad news man. Those tanks parts are molded in and can't be replaced. Also bad news is I had a nearly new stock tank and couldn't get rid of it, so I threw it in the trash.
Post up in the wanted section of the forums and see if someone has a used one laying around. Enough people have gone to aftermarket tanks that you should be able to find one.
Lastly, get one from a salvage yard. Will cost waaaaaay less than new.
Old Sep 23, 2015 | 08:39 PM
Originally Posted by Invest2m4
Yeah, bad news man. Those tanks parts are molded in and can't be replaced. Also bad news is I had a nearly new stock tank and couldn't get rid of it, so I threw it in the trash. Post up in the wanted section of the forums and see if someone has a used one laying around. Enough people have gone to aftermarket tanks that you should be able to find one. Lastly, get one from a salvage yard. Will cost waaaaaay less than new.
Hmmm... Aftermarket tank eh? Compatible with factory skid? Larger storage? Or are we talking fuel cells for not your daily driver Jeep?
In Canada so the wanted section is a pretty long shot. Thanks for the heads up on not being able to get the parts. Gonna try more epoxy to see if I can get the gas cap warning to go away, better stay out of the deep water in the mean time lol
Old Sep 24, 2015 | 06:06 AM
Maertz's Avatar
I tossed mine aswell... Invest has a custom tank if i recall, i am running and rci behind my rear seat on my daily.
