Altitude pulley help 2007 jeep jk supercharged
Old Sep 23, 2015 | 07:19 PM
Jasoncinpean's Avatar
Default Altitude pulley help 2007 jeep jk supercharged
Hey guys, my buddy that helped well installed my supercharger is not in town and can't help with this. I got the altitude pulley for the ripp supercharger. Got a 2007 Jeep Wrangler jk. Can someone help me out on guiding me how to remove the old pulley and put the new one on? Thanks!
Old Sep 24, 2015 | 03:23 AM
blockrockin's Avatar
the attitude pulley does give you some nice added boost... !! i put mine on a year ago or so.. from what i remember you have to loosen a few brackets, take the tension off the belt and remove it . i used a impact gun to remove the pulley belt, otherwise it is hard to keep it from spinning.. might be a video of how to do it.. not hard once you see how it is done. ill check around
Old Sep 29, 2015 | 08:18 AM
Thanks help me with the install, I'm making 12 psi now lol
Old Sep 29, 2015 | 09:46 AM
wow very nice ! glad you got it figured out
Old Sep 30, 2015 | 03:36 AM
DaK's Avatar
DaK
Have seen close to 11 with my altitude pulley and I am at 2600'.
Old Sep 30, 2015 | 08:37 AM
SAJK's Avatar
Default 11 or 12 psi
Is that even safe in a 3.8? It is quite a bit of boost for a N/A designed engine.
Old Oct 1, 2015 | 03:15 AM
DaK's Avatar
DaK
Not if you are at that level of boost all the time. For the most part the jeep never sees more than 5lbs of boost and even then its for a second or two. S/C was purchased to improve fuel economy and assist in getting us up some of these long steep grades we have to traverse just get to our wheeling spots.
Best mpg I've seen to date has been 17. That's rolling 37x13.5x17's Toyo's with 5.38's on a fully armored and loaded 2dr.
Old Oct 1, 2015 | 10:40 AM
Not if you are at that level of boost all the time. For the most part the jeep never sees more than 5lbs of boost and even then its for a second or two. S/C was purchased to improve fuel economy and assist in getting us up some of these long steep grades we have to traverse just get to our wheeling spots. Best mpg I've seen to date has been 17. That's rolling 37x13.5x17's Toyo's with 5.38's on a fully armored and loaded 2dr.
Can't wait to regear dang. What year jeep? Did u notice a big difference regearing with the supercharger? Quaker acceleration and such or?
Old Oct 2, 2015 | 03:18 AM
DaK's Avatar
DaK
Regear was done first so can't speak to it in that sequence but of course we saw a big jump in performance with the addition of the S/C. Even my wife noticed and that right there speaks VOLUMES.
Old Oct 2, 2015 | 09:26 PM
Regear done before or after the 37s? If it was done after 37s did h notice a large difference between stock gears large tires and than new gears large tires. I know there's a difference but was it large?
