Bump stops
Old Sep 27, 2015 | 04:55 AM
Gitzen's Avatar
Default Bump stops
I'm running a 2.5 rock krawler flex lift paired with fox shocks. Any input on what size bump stops to run use with 35s and flat flares.
Old Sep 27, 2015 | 05:22 AM
TheDirtman's Avatar
The generic response would be 2" as 35" tires are roughly 2" taller above the hub then factory. You might double check the collapsed length of the new shocks compared to the factory ones but I doubt they are more then 2" longer.
Old Sep 27, 2015 | 05:56 AM
karls10jk's Avatar
For that kit- absolutely check it before you drill or order anything. After you receive your new parts, check again to ensure that the bumpstops are going to contact the pads on the jeep- before you drill where RK says to drill.
