Dynatrac Prosteer Balljoints & Reid Racing Knuckle Fitment Issues - Help?
Old Oct 2, 2015 | 03:17 PM
thegoat's Avatar
Default Dynatrac Prosteer Balljoints & Reid Racing Knuckle Fitment Issues - Help?
In the process of lifting my Jeep I Have added a used Dynatrac ProRock Unlimited with Prosteer Balljoints, I am adding the Reid Knuckles to this setup. The Balljoints were just rebuilt and the "old" knuckles fit fine, but the new Reid Knuckles won't seat far enough to get the cotter pin through.
From the left side / right side there is 1/8" difference in the gap from the top of the knuckle to the bottom of the C. I.E. 1/8" gap one side 1/4" gap the other side.
Pulled the shaft from the balljoint and it still won't seat far enough to get the cotter pin through. We are going to see if there is an issue with left versus right.
I spoke to Reid Racing... Great customer service BTW. The said they CNC the part and check with a CMM to verify accuracy, so it being a machining issue is very unlikely.
Any thoughts or suggestions?
Old Oct 5, 2015 | 08:30 AM
Dynatrac's Avatar
Sponsoring Manufacturer
I'll share you situation with our tech guys, see if they have any info on this kind of fitment issue.
Old Oct 5, 2015 | 08:39 AM
Dynatrac's Avatar
We've not encountered this particular problem before, our tech guys are looking into it, as soon as we can give you some solid help with your issue I'll post it here.
Old Oct 5, 2015 | 08:58 AM
Invest2m4's Avatar
I'd recommend getting an accurate depth measurement on the knuckles. In theory, there shouldn't be any deviation, but I've seen it before on parts where there is a random one-off issue.
Had a brand new Yukon air locker and couldn't get a shaft in. Yukon said it is not possible that the locker splines were the issue. Well, turned out one side was screwed up. According to Yukon, that was a first for them. They replaced it.
Old Oct 5, 2015 | 09:17 AM
thegoat's Avatar
One of the shafts on the balljoint is different from the other, thus causing the fitment issues.
Old Oct 5, 2015 | 09:19 AM
Invest2m4's Avatar
Sounds like you have your problem figured out.
Old Oct 14, 2015 | 08:54 AM
thegoat's Avatar
Swapped ball joints and everything went together with zero issues.
Old Oct 14, 2015 | 10:52 AM
scooby snacks's Avatar
When you say you swapped ball joints, do you mean you put in a different set or did you switch the left with the right or the top with the bottom and vice versa? Just curious...
Old Oct 14, 2015 | 01:26 PM
thegoat's Avatar
I replaced the DynaTrac ball joints with Synergy ball joints.
Old Oct 14, 2015 | 01:39 PM
I thought so... just wanted to make sure I wasn't missing anything... thanks!
