Dynatrac Pro Grip Brakes with Method 105 BL or Chamber Pro 2?
Old Oct 8, 2015 | 06:42 AM
Biginboca's Avatar
Default Dynatrac Pro Grip Brakes with Method 105 BL or Chamber Pro 2?
I have the Dynatrac Pro Grip brakes, love them. Wondering if anyone has used this brake kit with either of these bead lock wheels?
I'm getting close to buying some beadlocks I just need to know what fits with these brakes...
Old Oct 8, 2015 | 07:56 AM
Invest2m4's Avatar
Not all that helpful, but I run the Chamber Pro IIs on my D60 that came off a 2010 F350 and the brakes are freaking massive. They clear, but it is tight. Only brakes I have heard that don't work with most 17s are the ones on the new UD60. You can run the Chambers on any of the Prorocks, can't imagine they made larger brakes for the stock JK.
Old Oct 8, 2015 | 09:15 AM
Biginboca's Avatar
Thanks for the reply! I'm hoping you are right I just would like to have it confirmed with someone who has the set up. The chambers are what I really want to run.
Btw, I can't find the weight of the chamber wheel. All I found was Amazon has it listed at 34lbs but they also have the slab listed at 34 and when someone actually put one on a scale it was 44lbs!
Old Oct 8, 2015 | 09:26 AM
Invest2m4's Avatar
Honestly, just give Dynatrac a call. They will know for sure. Then you don't have to guess.
I'd bet that 34lbs is without the ring. 44lbs sounds a little high, but probably in the neighborhood. Work great for me. I had the slabs before the Chambers. If you wheel a lot, get the monster valves. You will love them! I can air my 40 down from 25 psi to 7 in about 15 seconds. You clip the gauge on one stem and let it fly. Only issue is that you can't use the second valve hole. So, I have three valves per wheel. Hahaha. Oh well.
Old Oct 8, 2015 | 09:29 AM
Northridge4x4's Avatar
Sponsoring Vendor
The Chambers are 50 pounds each shipping weight so you may save a couple of pounds once they are out of the box and assembled. The ProGrip kit should fit fine with the Chambers. Were you wanting Black or Machined finish?
-Tim
Old Oct 8, 2015 | 10:46 AM
Biginboca's Avatar
-Tim
Looking for black...
Old Oct 8, 2015 | 12:29 PM
Sponsoring Vendor
Sent you a PM
