Random Low Tire / Security Light While Driving in Cold Weather
Old Nov 12, 2015 | 09:00 PM
ABNjk09's Avatar
Default Random Low Tire / Security Light While Driving in Cold Weather
Not sure if the video will work since I copied it from my post on wayalife, but if anyone else has experienced this please feel free to advise. I keep getting a low tire pressure indicator along with a chime and blinking security light (red dot) when it gets chilly outside. It is annoying as heck and I can't find a solution. It occurs randomly while driving and only when it's less than 40 degrees. I don't have a security system, no DTC codes populate in the dash or in my superchips tuner, and my tires are always kept around at 33-35 psi for daily driving. I reset the TPMS to 25 hoping that might influence the issue; no luck. Has anyone else dealt with this? I've seen a bunch of posts online but no solutions. Thanks in advance for any help and happy trails!https://youtu.be/c9fwBve0_Y0
Old Nov 21, 2015 | 02:25 PM
Yazan's Avatar
Arrow I had the same problem!
I had the same problem a while ago after driving 20 MPH over a bump, Low Tire ignition started flickering while I was driving, so to get rid of this annoying issue, I recommend:
- Check your battery status and (Brand)
- Reprogram your Jeep
Let me know if it works
